BlackPanther
Hyper-Fast Recumbent Riding Member.
- Doncaster.
Just adjusted the disc brakes on the Catrike. The big outer wheel wouldn't adjust by hand, and you need one of those star shaped bits.
It's an idiot proof, straightforward task.
1/ Insert bit in driver end.
2/ Screw to adjust the pad in.
3/ Remove screwdriver.
4/ Squeeze brake lever.
5/ Spin wheel to check pads not catching.
There's a step missing though.
3A/ Check that when you remove the screwdriver, the star shaped bit doesn't stay in the adjuster, because if it does, when you do step 5 it can break 2 spokes.
6/ Get yourself off to Halfords and see if they stock spokes fo a 16 inch wheel!
