Inner padding for specialized helmet
Cuchilo
Prize winning member X2
London
I have a specialized echelon 2 road bike helmet and latey its starting to rub on my forehead . Ive tried moving the padding it came with but its very thin and I just ended up with Velcro rubbing on my forehead . it came with pads to use if this was a problem but they are quite thick and make matters worse by making pressure points .
Can i buy different padding to go inside with out covering any of the airflow holes ?
Rob3rt
Man or Moose!
Manchester
Can often buy replacement pads for helmets. Consult the nearest LBS that stocks Specialized, they should be able to order in the pad set for your helmet.
