Exact same thing happened to me last year although I was just using cheap Halfords inners. I just assumed it was a bad batch and carried on and it's never happened since.Twenty inch.
Recomendations for a decent, heavy duty tube. Two failures in the same day(within an hour) on the area around the valve seating.
Nothing from inside the tyre, just plain failure. At £15 each, I expected better.
I sometimes think you are as well with the cheaper ones as long as the tyres are good. Or it may just have been luck.Require four. "Get me home tube" from PoundLand in at present.
80 - 100 psi inflated.
Tyres have a puncture protection liner fitted.I sometimes think you are as well with the cheaper ones as long as the tyres are good. Or it may just have been luck.
Still remember Durano plus punctured in the morning and again on the very next commute home. Glass hit the protective strip on the edge then worked it's way in from there.Tyres have a puncture protection liner fitted.
Two in an hour bad luck!!
Tyres are okay, protection from rim punctures has been upped, foam from a sleeping mat used. Then the tubes failed.Still remember Durano plus punctured in the morning and again on the very next commute home. Glass hit the protective strip on the edge then worked it's way in from there.
Nice.Tyres are okay, protection from rim punctures has been upped, foam from a sleeping mat used. Then the tubes failed.
They're wanted for this,
