innertubes
Flyboy
Tranmere
Tubeless
I have them on the flat bar bike (came with the bike), not noticed an issue (other than the valves getting stuck with the goo)
Probably not as heavy and slow as M+ but you'll get fewer punctures with the tyres and less mess than with slime tubes if you do
Slime every time, less time spent fixing p*******s at the roadside.
dim
Cambridge UK
if you don't opt for tubeless, ... it's the tyres that count the most and not the inner tubes
if you have a roadbike, and don't want punctures, get a tyre such as Schwalbe Durano Plus .....
if you have a crap tyre that will allow a flint or thorn or glass to penetrate the tyre, no tube will stop a puncture
Pale Rider
Depends a little on the size of tyre.
Slime isn't quite so clever in narrow roadie tyres at 100psi+.
As @vickster says, slime can also clog valves, so it's better used with schrader tubes which have a more easily removable core and bigger hole.
Slick
I use the durano + and got another puncture within 6 first couple of weeks. Touchwood, I haven't had any since though.
