I get frustrated with the fiddly stuff so am quite content to give stuff to the mechanic at the bike shop to fix!
Incoming ... duck!!!Weren't you worried about your nails?
Phew ... relax all.nail polish still intact! made sure i held the pliers and the alun key correctly!
So the other day my chain wouldn't go on the big ring so i thought, sod it, i'll try it myself. so while it was in the small ring i got my dad's pliers, held the wire, unscrewed the bolt, pulled the wire through as hard as i could with the pliers, and screwed it back up.
and hey presto... it worked.now my chain goes on the big ring again.
Well done, but its a lot easier than that. First to try would have been a twist of the barrel adjuster. If that didnt work a shift to the small ring then a tightening of the cable similar to what you done but you don't have to pull hard and then you'd finely adjust with the barrel.
You don't need a barrel adjuster for the second method, its only for fine tuning.but that would only work if you had a barrel adjuster on it? Right?![]()
so still feeling smug![]()
