bikingdad90
Hi, our boiler is on its lasts legs (17year old) and we need a new one. We are considering taking out the boiler from the kitchen and the water tank from the airing cupboard directly above the boiler and fitting a combi in the loft.
The loft is already boarded out and you can stand up in it. There is strip lighting, all I need to fit is a guard rail and fixed ladder.
The house is about 20 years old,has cavity wall insulation and meets current insulation regs in roof.
As there is a wall in the loft the flume will go through the wall instead of the roof.
The plumber also suggested wireless controls and a pressure gauge outside the loft so it can be programmed and monitored from outside.
Is this a silly place to locate a boiler or would it be ok as the plumber suggested the location?
) The reason that it takes so long to get hot water is simply the distance from the boiler to the kitchen tap, don't forget that you've to get rid of all the water that is past the boiler before the stuff that has been heated gets there, nearly a bowlful in our case.
