Is it safe to ride on carbon fork with scratch
mamil
I have a faint line on the carbon steerer tube, there's no sign of any damage inside, is it safe to ride or should I replace it? Pics attached
Webbo2
That looks the imprint of where the stem has been. Is there a crack.
midlandsgrimpeur
It is very hard to tell from a pic, but the third photo down does look like a compression mark (perhaps made by the stem, as per Webbo's comment).
Rub your finger over it, if it is a compression mark you will quite clearly feel some indentation in the carbon. If it is a scratch, the tube surface will feel flat/level as normal, you will just feel a small abrasion from the scratch.
If it is compression, then it is time for a new fork.
Webbo2
Why would compression indicate a new fork, I thought it’s extremely hard to crush a carbon tube.
midlandsgrimpeur
If it is caused by an impact or over tightening, it can cause fibres to break or internal delamination, both of which are going to result in the tube cracking at some point. I have had two forks replaced previously where the headset has become loose, this caused the fork steerer tube to compress as it pressed against the bearing race. The compression caused indentations and eventually cracked the steerer tube on both occasions (two separate bikes).
Don't know but it would not be a problem with a steel fork.
Webbo2
Oh dear I might have start looking at some steerer tubes now.
