MountainSide
My front v-brakes were releasing slow. As it happened braking wasn't affected but I like to flick the brake lever to make a loud click which is quite an effective alternative to a bell and the slow cable stopped this.
Anyway I could see it was the cable binding and noticed the lining between the inner cable and metal noodle curve seemed to be fowling. I pulled it out (seemed to be about 2 or 3 inches of it) and it was all cracked and split.
It all works perfectly again but anyone any experience of whether I need to replace the noodle (the metal part of the end of the cable that turns 135 degrees or so) or will it continue to work fine. Maybe leave it unless any issues develop and just lubricate? I imagine the lining is probably there for a reason. Maybe my inner and outer are now metal to metal.
The rubber boots are pretty shot anyway so might not be too bad to buy them as a set.
