Is there a average psi or is it just the range printed on the tire?
Randombiker9
So I bought a new pump (Track pump that has an actual gage on it). My tyres say 40-65 psi . So do you just pump anywhere in between those numbers or is the average sum to work out which PSI you should be on?
Anywhere between those numbers.
I pump to the higher (plus a bit) - easier rolling, and less liable to punctures. By the time the pressure has dropped to the lower ... time to pump up again :smile:
Some bods will give you some complicated calculation between tyre width, your weight, road surface etc.
I generally would go with between the ranges but the higher the number, the less resistance but harder the ride. I prefer to have it near the top end. Bumpy but to me feels quicker.
Loch side.
CanucksTraveller
Hertfordshire
I tend to go for the top figure for faster rolling and to keep punctures away, maybe start there and back it down for a bit more comfort if you feel it's necessary.
steveindenmark
My Schwalbe Pro ones say up to 95psi. On road I have them at 80psi on dirt tracks 60 psi. At 95psi it would be a rock hard ride.
You need to try different pressures and see what is good for you. I take the numbers on the tyre as a guide.
Randombiker9
Randombiker9
Ok my bikes a hybrid that's why it's got range of 40-65 psi
If it rains, I've heard it's better to have a lower psi to get more grip is this true or a myth?
Tangoup51
The PSI printed on the side is nothing more than the Limits of your tire. - You should never go below 40 and you should never go higher than 65. - There are exceptions, but it's within this ball park you want to sit.
And yes, the sum to calculate your tire pressure is easy! - Input your Total weight and Tire Size into any online tire chart and you can get a solid PSI to work with.
