It's happened
Crandoggler
Used my turbo a few times now and checked my rear tyre out.
It seems I have scores, or scratches along the tyre. Not overly sure why or how this has happened.
I'm aware that a spare wheel is ideal for a turbo, but I don't have that luxury. So what could be doing this? The roller is polished and doesn't have any rough areas. I can't imagine the heat is causing this? Anyway, shall I just use that tyre as a turbo only and buy a new one?
Could be heat or friction. Depends upon how much pressure the roller puts on the tyre.
I've used Michelin Pro Race tyres on a turbo with no problems. I do have a spare wheel with a cheap tyre on for such purposes.
The only problem is somebody borrowed my turbo and forgot to return it for the past two years, didn't you Gaz.
:rolleyes:
Crandoggler
Crandoggler
Seems like this could get expensive lol. Only takes 5 mins to change a tyre I guess. But I'm a human and instinctively lazy.
There are specific 'turbo tyres' you can fit, the compound is very different to a road tyre, and they are deigned to work with roller resistance type turbo trainers
http://www.wiggle.co.uk/schwalbe-insider-folding-turbo-trainer-tyre/
These are the best I've personally used.
The other alternative, is to get a cassette fixed turbo trainer.
Again the best I've used, others are available
http://www.wiggle.co.uk/wahoo-kickr-power-trainer-1/
Crandoggler
Crandoggler
Not a cheap hobby is it.
I've literally just bought the trainer, so it's going to stay. May buy a spare wheel,cassette and tyre though. For now this will have to do lol
RussellZero
Wannabe Stravati
Do those who use a spare wheel with cassette not have any problems with chain wear/match when moving between road and trainer on a regular basis? I always thought the chain and cassette wear together so if you need a new cassette or chain you replace both at the same time. Am I mistaken? Spare wheel sounds like a good option for turbo. I'm on rollers at the mo so not an issue, but this was one of the concerns I had about going to a turbo - now looking again because of zwift and other software improvement options
