I think they do it on purpose to make you overcome the problem.
Take the option that gives the most professional result.
If it is jobs then put continued on attached sheet and on the attached sheet list jobs in same format as they had carrying on from the form.
Any that look like you have done a quick job or it does not look professional will go in the bin. So perfect or dont bother.
My sister worked in recruitment for a big firm. One job often had 60 applicants. Advert said "write to Mrs Smith at...." all the ones with "Dear Sir/Madam" were discarded on opening.
They will set you hoops to leap through. Just jump!
