My chain is jumping. It is fine in the higher gears (smaller sprockets on the cassette), but once you go into the lower gears it will make a kind of clicking noise and "jumps" so that the chain slips (very annoying on the hills, nearly came a cropper for one).
I was thinking perhaps worn cassette (I changed the chain but not the cassette), but it was perfectly fine to begin with. I tried changing the gear cables and cleaned and lubed the rear mech & jockey wheels and now it does it still, but on different gears than previously (instead of the second lowest sprocket at the back, it is now the lowest sprocket at the back etc). I'd have thought that if it was the cassette it would be on the same sprockets every time?
Also to begin with I could use all the rear gears on the middle chain ring, and it would only jump on the lowest gears when using the granny ring. Now it does it regardless of what chain ring I'm in.
Any ideas before I ask Santa for a new chain and cassette to see if that solves it.
Ta
Ta
