THIS grinds my gears......
sevenfourate
Devotee of OCD
..........chain / drive-train lubrication.
Apologies if this is the 4-trillionth thread on it. But having quite a few bikes, and hoping to do alot more riding this year - i'd like to not be 'maintaining' in every spare interim moment :whistle:
I've religiously been using Tru-Tension Bannaslip with Tungsten for a couple of years (?). Came recommended and is pretty highly rated [4.4/5 on amazon]. After cleaning up old. application of new and drying the drivetrain sounded GREAT. Quiet, slippery etc. And lasted for 100-150 miles before i could hear the difference. No huge issue as i'm a serial cleaner. So a quick wipe / re-lube was not too much hassle once i already had the bike upside-down. **It went on / was kind of a Grey colour; but by 100 miles was pretty 'Black' - and i'm not sure if a component of it was Oil-based. But it soon changed colour. Indicating it was changing / picking up dirt etc
https://www.amazon.co.uk/BananaSlip...9103880789-B07TWG1KTT-&hvexpln=0&gad_source=1
So before i went on Holiday i literally stripped the chain completely, 100% thoroughly cleaned the rear sprocket / front mech with spirits until spotless - and then lubricated with some Weldtite Dry Wax - which again had good reviews and i happened to have some i didn't know about [4.4/5 on Amazon]
https://www.amazon.co.uk/WELDTITE-D...19666-B00WKRC4FU-&hvexpln=0&gad_source=1&th=1
I came back from Hols and did a 50km / 31m ride on Tuesday in the dry. And 25 miles commuting yesterday - so 56 miles total. And the chain sounds dry / noisy as heck compared to when freshly lubed. Surely this can't be normal / expected so quickly ?
*I may be getting close to new chain time (?). I'm imagining from looking at Strava mileage records; this one could have done around 1500 miles. Most of that in Winter. So i'm probably going to change that regardless at the weekend. **Rear sprocket and crank sprockets are both newer than the chain.
But how many (Predominantly 90% dry) miles should i see before seeing / hearing / noticing serious degredation of chain lubrication ?
Any / all / every thought and suggestion appreciated ^_^
Chief Broom
Im a 3 in 1 fundamentalists and couldnt be swayed by the new religion of ' Tru-Tension Bannaslip with Tungsten' :laugh: I clean my chain n sprockets after every ride and couldnt say how long before it started to sound 'graunchy' but would guess it might be getting dryish after 150 miles or so. My current chain has done about 6k with my OTT cleaning regime and has no measurable wear im wondering how long it will last! :okay:
sevenfourate
sevenfourate
Devotee of OCD
I'm 300% OCD. Born of my Engineer mentality. And i'm happy / would love to clean and re-lube after every ride'ish. Heck; my longest rides are only 40-50 miles...so i'd be safe with that. BUT: i work long hours. And am out very early; often back very late. If im going to be commuting regularly this Summer i'd be cleaning chains at 2am or 11pm. Hence i'd like to clean / lube a little less often whilst still dulling my 'chain noise OCD'.
Also sound's like without rotating pre-waxed chains or using some amazing (Expensive ?) drip wax: 100-150 miles before clearly noticing a difference and using on 'ok' lubricant as i am - might be about all i can reasonably expect.....
**Cough** Belt drive :whistle:
All uphill
Still rolling along
Somerset
Also sound's like without rotating pre-waxed chains or using some amazing (Expensive ?) drip wax: 100-150 miles before clearly noticing a difference and using ont 'ok' lubricant as i am - might be about all i can reasonably expect.....
Warning: the following contains heretical comments.
9 speed chains don't cost much. If you have to replace them after 1500 miles it's not going to break you.
A quick wipe after a wet ride with an oily cloth is fine. Check the chain wear regularly and replace as needed.
No need for feelings of anxiety or guilt.
Note: if you have been affected by this message please ask for help.
sevenfourate
sevenfourate
Devotee of OCD
I have two spare decent-quality chains and multiple quick-links for that (3 x 8 speed) bike in-stock at home already. The cost isn't as issue. Hence i thought for 'no money' i'll change it regardless. Being an Engineer i have some comprehension of how much 'wear / stretch' 1500+ gritty and wet winter miles could do. And some of that wear isn't perhaps measurable with a standard "measure distance between rollers" method.
So, out with the old - in with the new along with a full-clean up of the drive-train Saturday. I'll report back with my findings. It may just help someone in the future....either way !
Cheers for your thoughts.
a.twiddler
Many years ago I was a high mileage motorcyclist before the advent of sealed link chains. I was into the rituals of boiling your chain in wax every few weeks on the kitchen stove (Oh how my dear old houseproud mum enjoyed that!) and keeping a ready boiled spare hanging on a nail in the garage. Among the things that exercised my mind then were considering the virtues of alternatively reversing the orientation of the chain to the sprockets so the pins and bushes would even out their wear, different types of chain wax, the best automatic oiler that might eliminate the chain boiling rigmarole, how often to replace the spring link. The advent of sealed chains reduced the maintenance needs but made the chains themselves much more expensive. I do a lot less mileage these days but my last three motorbikes have had shaft drive.
For the vast majority of bicycles the chain is part of the variable gearing mechanism, so there's no getting round its maintenance needs but you can get carried away. There's a lot of marketing involved in chain maintenance but they are pretty tough things, unless you spend your time beach racing and covering it in sand. For my purposes, I'm of the Keep It Thimple, Thtupid school of chain maintenance, and it just works for me. Of course for others, YMMV.
Mike Ayling
Mike 1942
Note: if you have been affected by this message please ask for help.yven lesd
And eight speed chains cost even less!
sevenfourate
sevenfourate
Devotee of OCD
After ‘much’ reading reviews, Googling ‘Best Chain Lube’ - THIS featured in many reviews / Top 5 products etc. AND looked to be based around primarily dry riding, but could handle some moisture. Ie: Right up my Street and style of riding.
Now; having gone this far in - and ignored the numerous 🙄 other products I have filling a shelf in the garage ready for the next ‘Wonderlube’: if anyone has something negative to say about this product - can you please move on and keep your options to yourself 🤣🤣🤣
presta
For 35 years I used nothing more exotic than the can of engine oil on the shelf in the garage. When I started long distance touring I switched to Finish Line for no other reason than it was a convenient sized bottle to carry in the pannier, and I've continued to use it because I've learnt from experience that the bottles can be trusted not to leak.
sevenfourate
sevenfourate
Devotee of OCD
Now in the process of installing new chain.
Not an exact science (And it’s probably just over 1/2 link in reality) - but new is top. Old is bottom. How does this amount of stretch rate on the 0-Fubar’d scale ?
**Looks a reasonable amount to me. And my ‘crude’ manual chain checker barely went in on the new. And the spike nearly disappears completely on the old 😳
