Kitchen botherers of CC - pointers on pan purchase please!
sungod
I broke a cast iron pan on a newly-installed induction hob - it split in half when I gave it some serious heat! Never heard a sound like it. I can only think the pan had a casting flaw.
could be, induction hobs can pump a lot of energy into a pan - a few kilowatts on the highest setting - so a cold pan will experience large temperature differentials if heated fast, which will stress it, same as plunging a very hot pan into water can damage it
an equivalent gas burner would heat the sides as well, but induction heats the base and the sides only heat through conduction from the base
for frying pans (and wok), i prefer carbon steel, far lighter than cast iron and very fast heating/adjusting on the fly, once seasoned the pan is pretty much non-stick
wafter
wafter
Oxford
Crikey - that escalated from zero to "an intimidating amount of responses" quickly :tongue:
Thanks for all the thoughts; lots to digest so probably easiest to do this individually...
Hello again @wafter, how are things?
When I clicked on your thread, I thought you would have a gazillion answers already.
Tbh, for what you are going to use it for, any old pan will do.
I say old, because charity shop cookware is often solid, good old fashioned stuff.
If you want to spend serious money, go to a catering shop - also online - like Nisbet.
You will be hard pressed to find a catering standard frying pan with a wooden handle, though, because they have a tendency to split, but you can replace them.
A quick search on Ebay, I found many mid market stainless steel frying pans with a wooden handle.
Have a look.
If you make a lot of omelettes it's worth having a dedicated pan for them imo, doesn't have to have a non stick coating, it will become non stick with use ^_^
Edited to replace aluminium for stainless steel - had a brain freeze lol
Thanks Pat - currently buried under a pile of nature's gifts from the garden; hope all's well in your part of the world!
It was a bit slow to start, wasn't it?
I'm very happy to go old / used and the ideal was to pick up some cheap second-hand cast iron, however so far everything I've found in charity shops has been cheap / tatty / new / non-stick..
I'd not considered that perspective re. wooden handles; although I'd also be happy with all-metal with integral / riveted handles. Wood would be nice though too. I'll take a look as you suggest. Likewise thanks for the suggestion of Nisbets - I've dealt with them once before and I'd certainly feel more confident dealing with a legit catering / trade supplier than one of the more commercial, public-facing peddlars of rubbish one might find on the high street.
I'm not averse to having more than one pan, however on both space and cost grounds wish to keep the inventory minimal so each would have to have good justification. Why do you suggest a separate omlette pan? Tbh with any frying pan I've generally got into the habit of only cleaning it when it gets really manky / I've cooked something I don't particularly want flavouring what comes afterwards (fish, for example) so they all get "seasoned" :tongue:
If you dont want aluminium or coated pans and the cast / spun ones are overkill then just get a decent stainless one. Personally I wouldn't bother with the copper coated ones, it soon comes off after a bit of use. There are ceramic ones but never had or used one. We currently use stainless after eldest gave us greif over various coatings and aluminium pans causing various health problems. Suspect he might be right but I'm not telling him so.
Spun iron appeals but the only ones I've seen are probably more pricey than my modest "skills" would justify.
I was looking at solid copper rather than coated, although again I'm not sure whether their intrinsic qualities would suit / be required in my use.
"Ceramic" is just another nasty cynically-marketed gimmick IMO - typically my mum bought one a while ago and it's just aluminium with some sort of coating (I assume something similar to "Cerakote" - probably a ceramic filler in a temperature-tolerant polymer matrix). A year or two later the finish has flaked off in areas of contact around the rim causing the underlying ally to oxidise, while my oversight saw it left empty on a hotplate (turned the wrong one on) which caused the nasty placcy finish to scorch and go black (again, a pure ceramic would never do this as their melting points are incredibly high).. so it's now yet more expensive, wasteful landfill.
I'm absolutely with your eldest on this one - very skeptical of the long-term health implications of the finish; as at the end of the day it's just another plastic in contact with your food as you heat it.. so can see it being another health scare in ten years' time.
My mum also suggested "Titanium" - again yet more deceptive marketing tripe as a full Ti pan would be thousands of pounds and its intrinisic properties probably crap for such an application in any case. IMO if everyone involved in marketing was herded up into a box and dropped in the sea the world would be a much nicer place..
Ironically my mum's now back on a good old stainless / copper-bottomed frying pan she's had for decades; having wasted probably hundreds over the years on gimmicky sh*te :sad:
Le Creuset triply stainless pans will last forever and are excellent. If the worst ever came to the worst the LeC guarantee is cast iron (see what I did there!). Or Nisbets own label as suggested.
Thanks - hadn't considered them as I'd written off their cast iron efforts for various reasons.. will give them another look. Thanks also re. Nisbets!
You're overthinking this. It's not like making an important decision such as Shimano vs Campagnolo or some such.
Go to a shop, go to the pan isle, pick up a pan or two, make some flappping movements, sweep your fingers over the surface, choose a colour and pays your monies. On your way out, go past the offie and get a beer.
Of course; my mum favours your approach - which probably has something to do with why we seem to get through a new pan every five minutes..
Cheers - not after a set but will certainly give the site a good coat of looking at!
If going for pans with a non stick coating, make sure they are PFAS free. If they don't say they are PFAS free, they won't be.
https://en.wikipedia.org/wiki/PFAS
Not going for pans with non-stick coatings as I suspect PFAS' might be the tip of the iceberg..
If you don’t mind bunging mullar to Mr Bezos, the pinnacle range of cast iron pans are quite good and don’t cost the earth.
We have one and just need to season it every so often.
Pinnacle Cookware - 12inch / 30cm... https://www.amazon.co.uk/dp/B0797VZJWR?ref=ppx_pop_mob_ap_share
We also have an overmont that we use for dishes and some frying of
Onions etc https://amzn.eu/d/3nENsu8
Unfortunately I do mind; but thanks for the thought :smile:
I'd get an all-stainless steel one with deep sides. And with a lid as well.
An all-stainless steel one can go in the oven / under the grill if need be. And no need to worry about coatings or seasoning a cast iron one. Unless of course you're looking at an enamelled cast iron skillet...
If using stainless steel, use lard to fry, as you get far less stickage / stainage than with oil.
Cheers - hadn't considered a lid!
Yes; I think if it's stainless having everything hewn from said material would be the way to go.
I do like the idea of enamelled cast iron, however I think this would be too heavy in a size appropriate for a general use pan. I do see Le Cruset skillets come up used fairly regularly for not a lot of money though; and while the weight would be too much / the ribbed finish would be no good for general use, for the odd steak (where the skillet remains static on the hob) or grilling / ovening stuff one could be pretty good :smile:
Thanks for the heads-up re. lard; wasn't aware of that!
Which type of hob do you have?
Gas; finally :tongue:
Get a moderately sized cast iron wok. Covers all the bases except eggs.
Add a small, but expensive, egg frying pan to your shopping list.
In the past Kuhn Rikon made some amazing pans, but they seem to be a front for Chinese stuff these days. Ours are 40 years old and still look good and work well.
Thanks - again not sure the weight would be amenible however.
No issue re. eggs as I prefer soft-boiled as they're less hassle and just as splendid :smile:
I was looking at Kuhn Rikon spun iron; they look great but perhaps a bit beyond my station... sorry to hear that they seem to have gone downhill.
Cast iron is cheap and lasts forever. Can be heavy and needs a bit of TLC though. Stainless steel is a bit more expensive (for a good one) but also lasts forever and is easier to look after and it's naturally non stick provided you use the right temperature and let the pan heat through before use. Check out "steel pan guy" on Instagram for tips.
Indeed and thanks - will take a look!
I would suggest a couple of reasonable quality stainless steel saucepans, a decent cast iron frying pan and casserole, Le Crueset casseroles are expensive but are an investment and last a lifetime, they can also be used on the hob and then in the oven. However Tesco, M&S, John Lewis etc all do their own versions.
Thanks; stainless seems like the obvious choice for saucepans although my query is more with the frying pan and as per the OP I think cast iron is going to be too heavy in an appropriate size. I like the idea of a casserole but tbh I think my skills are (for the moment at least) too limited to really make use of one.
Thanks - unfortunately ublock says no!
Cheers - will take a look!
Gunk
Oxford
Dunelm is definitely worth a look
wafter
wafter
Oxford
I know you say you don't, but there is a place for teflon/teflon-alikes.
This is the single most useful pan in our kitchen:
https://www.nisbets.co.uk/vogue-non...633F7lLYI9nKotzcFj-GGhy8wGXsbaI4aAtzKEALw_wcB
Add a lid and it's even more versatile. It's lasting pretty well, too - most will unless you give them serious heat (and then you'll die instantly anyway 🤭 ) which they're not designed for.
Not in my kitchen, thanks.
Cheers - gave that a good once-over last time I was in there and IIRC every frying pan was coated in some form of "non-stick" abomination..
Profpointy
Couple of thoughts:
Copper is the second most conductive metal (after silver) so is in many ways the best pan material, apart from the considerable expense and, compared to aluminium, weight. Copper must be be lined with stainless steel or (arguably obsolete) tin. 3mm is the minimum thickness for good quality pans. Beware of pans with shiny brass handles - they are usually thin and really for the decoration market - eg hanging up in olde worlde pubs and such. Copper is arguably the Rolls-Royce of pans
Beware of stainless pans "with a copper base" as a thou' of copper plated onto the bottom of a stainless pan is has negligible benefit. P
Cast iron is good for frying pans except for the considerable weight. Reasonable cost, stays flat, the surface "seasons" and with a bit of care and attention becomes non-stick (basically don't scrub too much). Cast iron isn't a great conductor of heat but they compensate by making the pan thick as the material is cheap.
Spun mild steel is also quite a good choice, and like cast iron, builds up a patina which becomes kind-of non-stick. Again avoid scrubbing too hard. Not nearly as good a conductor as copper or aluminium but reasonable. Shouldn't be expensive if you avoid poncy brands. The reasonably thick ones with a flat steel handle are the ones to go for.
Stainless isn't a great material for a frypan as it's a relatively poor conductor. Doesn't matter for boiling spuds or pasta but does for frying as you get hot spots. This can be mitigated by thickness but then it gets a bit expensive
Aluminium, despite your aversion has a lot going for it as it is lightweight, an excellent conductor of heat, and cheap. That said you probably want either some fashion of non-stick or have it in a stainless steel sandwich - and the later are expensive so you're well on the way to copper prices
I've heard some mention of titanium but in my view it is a stupid choice. It is expensive and a poor conductor of heat and it's only virtue is light weight which is rather a secondary concern in the kitchen. Its great strength is of no benefit. Ali is light weight, cheap and an excellent conductor so is better all round.
Anyhow all my pans are copper. Bought a few off ebay initially (check the thickness before buying) then gradually accumulated some Falk brand pans when they had a deal on. Yes they were expensive, and I concede the prices are even more brutal now, so whether I'd make the same decision I'm less sure. Maybe I'd just get a couple of choice items rather than a whole load. Something like a 28cm saute pan does double duty as a frying pan and a low saucepan for example. Or something with two loop handles like the cauldron type can be used in the cooker as well as on the gas. To he honest the normal saucepans are often used just for boiling veg or pasta and any old pan would do for that, so only really a benefit for soups and stews and such
Gunk
Oxford
The stainless saucepans are good value and they also do LeCruset lookalikes
