knocking together a wheel truing stand, one or two struts
Dr pepper
Regular
I want to throw together a sturdy truing stand from some angle iron.
The idea I have is to have just one upright that the hub clamps to, or bolts depending what the hub is, and have the vertical upright 'unplug' from the base.
Then building a wheel and lacing spokes with it in the stand might be possible.
Some sort of indicator can clamp itself to the upright for final truing.
Does this sound a good idea or a non starter.
ianrauk
Tattooed Beat Messiah
Rides Ti2
@Trickedem made his own wheel truing stand.
Way-Out-West
Pinno's attic
I think just a single upright wouldn’t be sturdy enough and would accentuate any bearing play coming from the hub. Lacing the spokes is much easier away from a stand.
I made a wheelbuilding stand using a turbo trainer as the stand and bolt an adjustable guide rail (which I made) to the turbo when needed and removable when not. Works well.
At a pinch you can build wheels in the bike rear triangle or forks.
Here's mine, made from a few scrags lying about the place
88robb
Netherland
That's a solid plan and a classic DIY approach. A single upright strut is all you really need.
The key is making sure your hub clamping method is absolutely solid and centered. Any play there will make truing impossible.
For the indicators, use two zip ties around the strut as your fixed reference points. Trim the ends and you've got perfect, adjustable gauges for both lateral and radial truing.
Dr pepper
Regular
I'd probably use 3.2mm wall 38mm tubing, strong enough to hold an engine in a car.
The idea sounds good as it'd be very small and handy enough to take with me to work / mates houses, there would be more stress on the hub than a 2 stantion device, but would it be as much as the hub in the bike with a 100kg rider.
Whatever I do being handy at fabrication I'll make it look nice and neat, and tough enough to win a fight with any abuse.
I like the croc clip indicator, 0 build time and readily useable for anything else deemed fit.
