I can't say I have ever seen a delivery rider out on one of these.
There is an option for a battery on the rear rack, but I reckon that is where my tent is going.
I don't think the battery position will bother me, just not sure of the motor size. 🤔
Not many e-bike charging stations in some parts of the world.
Believe @steveindenmark has a non battery version.
Any report I've read from owners with rack mounted batteries complain about the bike being too top heavy and problems fitting panniers.
75nm from the motor it's specced with is plenty for touring but you'll have to work hard up hills of 15% or more if heavily laden.
I'd be more concerned with the battery size. 13.4ah lasting 140km? Unless Bosch motors are umpteen times more efficient than Bafang alternatives, that seems far fetched.
My 20ah battery will power my 48v 750w Bafang motor to 144km IF I use it on minimal power (just enough to overcome motor resistance) on mostly level terrain with a tailwind for half the trip. I tested that.
If I was buying that bike, I'd go for the non powered version and fit an aftermarket motor and battery for a good £100 less. Plus, if you wanted to ever go motor free, converting back to a normal chainset and BB is pretty easy. Not sure if a frame tailored to a motor has that option.
For exampleI'm very interested in the regular one - the geometry seems spot on, i.e., slightly longer top tube than drop bar bikes, but nothing like an MTB; high-ish stack but not too high; long chainstay, etc. Looks like this one has the same geometry. But where can you buy them in the UK?
This is the thing.Charging on multiple day tours is a concern, but I'm hopeful I can manage that.
From all that I've read that's one of the great world touring bikes - at least the acoustic version.
I think @Vantage is spot on to consider battery capacity and range.
This is the thing.
It's not clear if you're camping or not but camping may involve higher costs or different pitches or even skipping certain sites if you're needing electricity or longer breaks as you charge up at a coffee shop etc.
If planning on going abroad it might be no harm to check out current regulations. As far as I understand it, E-bikes are definitely not allowed on planes and may not be allowed on ferries.
But as for a bike designed for Laden adventures in most conditions? Perfect!
