yorkshiregoth
Master of all he surveys
- Heathrow
downfader said:there is one benefit to a cyclelane that I never see discussed - it stops drivers from cutting you up (usually) giving you an inch between their rear bumper and your front wheel.
purplepolly said:True, usually, but last week I got honked and shouted at because I was going straight on at a crossroads and the cycle lane and driver both turned off to the left. He said I should have signalled.
In retrospect I should have pulled out and blocked the car earlier but on the other hand the driver was making an assumption because of the cycle lane which he wouldn't have made if there hadn't of been one.
But on the other, other hand, most of the traffic turns left there and when I have tried pulling out earlier, the drivers don't understand I'm going straight on, get irrate because I'm not in the cycle lane or moving over to the right hand turn lane, overtake and then cut me up by immediately turning left.
Maybe I should write to the council and ask them to paint the straight on bit of the cycle lane.
