jorgemartin
What should I do? Cut the steerer on my new fork and use a stem raiser? or leave the steerer as is and use spacers? Does it make a difference?
Thanks
Thanks
an excessively long steerer tube, with bars perched atop it, may impose stresses on your aheadset bearings that they are not designed to bear.
You can use as much steerer as you like with no ill effects. It's no different to slinging a high rise bar with an upright stem.
Mrs Mickle's Thorn Raven tandem has a good six inches of spaced out steerer showing. Snot a problem.
depends on how she/you ride.
