Did that, tried a few. No luck yet.Try your local bikeshop.
Why do you need it going over. Nowt to do with the manufacturer, because that would be my next port of call.Did that, tried a few. No luck yet.
Why don't you explain your gripe on here? There are loads of experienced cyclists who will be able to tell you whether you're wasting your time or not.
Most of the time, if you're contemplating civil action against a manufacturer you are looking at wasting a pile of money with not a snowflake's chance in Hell of any recourse. Litigation is a risky and potentially ruinous game unless you're very very sure indeed of your case.
You are quite correct. I have been involved in several commercial litigations in the past. It never goes to plan, always costs twice as much as was estimated. It usually boils down to who has the deepest pockets to maintain their position. That being the case, the big boy nearly always wins. I'd look for some commercial settlement and move on, almost regardless of the circumstances
Please clarify, is it just the bottom bracket component or the actual BB shell in the frame?To sum up very quickly, by bottom bracket snapped.
How much is the bike worth?To sum up very quickly, by bottom bracket snapped. After inspection we found it was a two stage fracture, the first stage fracture(the cause) we ar struggling to see how this happened as it would have taken a high energy impact to fracture the shaft the kind of energy to say if this happened while the part was fitted the bike would have been destroyed.
So I could do with an expert to examine the part.
I suspect the latter from your OP but your last post is ambiguous, to me anyway![]()
