Loose fit cycling tops
benb
Evidence based cyclist
Epsom
My work commute is only 10k, and I don't see the point of tight lycra for that short distance.
At the moment I wear normal T-shirts, which are comfortable enough, but the back flutters up in the wind, showing my lower back to the motorists behind.
Does anyone have recommendations for loose fit cycling tops that are cut longer at the back so they will preserve what little dignity I have?
Pearl izumi quest tour, £31 from Evans at mo
bloodlett
florida
I use bontrager soltace tee's same material as a jersey same cut even has a zippered pocket in the back but fits loose like a tee shirt
You may be sorted but the Quest is now a smidge over £20 delivered with the current extra 10% off promo code
http://www.evanscycles.com/products/pearl-izumi/quest-tour-short-sleeve-jersey-ec061241
jack smith
Durham
Start cycles and more mile jerseys £5 each in all colours, loose fit and have a rubber grip at the bottom to stop the, riding up
