ChrisEyles
- Devon
I was out on Dartmoor this afternoon, and on one of the long, out of the saddle climbs I noticed my rear shock felt a little different from usual. There seemed to be a little less preload (the back end was bobbing more) and a fair bit less damping, with a slight audible knock when the shock was topping out. For the rest of the ride it felt OK on the downhills but a bit too squishy on the climbs, and the reduction in damping, while not massive, was definitely noticeable.
I'm pretty clueless about servicing suspension units (I can dismantle an elastomer/spring based fork to re-grease but that's about it).... is it possible a seal has blown on the shock? I didn't see any oil on the shock body or piston, which I'd have expected if this was the case. The offending shock is a "shockworks" unit on a late 90s not-particularly-high-end Marin, with no damping/rebound adjustment that I can see.
Is it possible to revive this sort of thing with a garage overhaul? If so that'd be ace... but if not the bike was so cheap (£20!) that I don't think I'd be interested in replacing with a better, modern shock so I guess if that's the case I'll just ride it to death 'til it fails all together.
Any input much appreciated!
