Lubing chains
tyred
Ireland
For wet weahter use, you would be better off with a proper oil. Exactly what it isn't doesn't matter too much in my opinion. Oil won't wash off but will be messier. What you have there is nice and clean but for dry weather use and washes off in the rain.
Wipe the dust and dirt of the chain before applying the oil, just a little drop on each roller. Then run the chain a few times, and wipe again to remove the excess.
gaz
Cycle Camera TV
South Croydon
The finish line wet lube 'attracts' the dirt quite a bit. For this time of year, the dry lube version would be better.
Deleted member 1258
I've tried them both and personally I prefer the wet.
Allirog
My chain loves a regular dousing in WD40.
the_mikey
I've just cleaned and re-lubed my chain using Finish line wet, it works but like has been mentioned here, it does attract dirt quite quickly. Wax lubes are fine for a few 10s of km but will need to be re-applied, the benefit of using wax lubes comes from the wax falling off the chain, taking the dirt with it, but once the wax is gone it need replacing as you're left without any lubrication.
colinr
Norwich
I'd go with dry lube rather than wax. That should sort it.
If you're creaking is your chain a bit tight perhaps? It's not a new chain is it?
Allirog
Allirog, on 24 July 2011 - 07:04:09, said:My chain loves a regular dousing in WD40.
Oh no, someone said the "W" word!!
Sorry.I'll amend that inflammatory statement to;My chain loves a regular spray with a well known,bargain basement,silicone free H2o repellent lubricant of British manufacture.
