Pale Rider
My latest ebike has ludicrously wide handlebars - about 30" - which is daft for a bike designed for not much more than gravel paths.
So I set about the nervy task of chopping them.
My other bikes seem OK with bars about 25/26" wide, so I decided to take a little under two inches off each end.
Fair bit of junk on the bars to shift, and trust Herr Rohloff to leave a little tripwire for me in the shape of tiny Torx bolts on the shifter.
Following advice from my brother, my cutting weapon of choice was a C-type pipe cutter - worked OK and only cost £3 from Screwfix.
Just as well it was cheap, because I'm unlikely to use it very often.
Here's a before pic:
And here's after:
The eagle-eyed among you may notice I took the opportunity to have a minor rearrangement on the bars.
My cheapie Decathlon bar bag is now mounted lower down, taking advantage of the factory fit 'butcher's bike' front carrier.
Mr Garmin will now have to live on the right hand side, and I've angled the brakes and Ergon grips more to my liking.
Here's what I chopped, and the tool used to do it.
Looks a good job, well done.
Although I'm a great believer in the law of unintended consequences when it comes to bike fettling, so when I go for a ride tomorrow I may discover something doesn't work as well as previously.
And here's after:
