Andy in Germany
- Freiburg im Breisgau
I've mentioned elsewhere that I've gone and goot myself a new project:
The current plan is to make a 4cm deep top out of recycled pine (because that's what's available). I'd retain the existing frame which looks like it's beechwood and therefore very solid and make a basic laminated slab for the top as seen in this highly detailed digital rendering:
Given that the board should be a minimum of 40mm deep, and it'll be glued with white wood glue (often more solid than the wood), which way would people suggest making the grain run?
Crossways seems logical, especially if we only have short bits of wood in the store, but lengthways would leave less potential damage due to movement in the wood. I could get around this problem of course by making large holes on one end and putting washers under the screw threads but it seems less than ideal.
Any thoughts?
Any thoughts?
