Making mayonnaise. Which oil?
PK99
SW19
Culinary things I've tried, and decided 'life's too short' when it's generally good, and cheap, from local shops:
1) Making mayonnaise (I love mayo,though)
2) Making hummus
:smile:
Shop bought mayo - even the premium examples - is but a pale imitation of the real thing
Mayo:
Blend :3 egg yolks and teaspoon dijon mustard in magimix, or bowl if using stick blender.
While blending: add 350ml groundnut or grapeseed oil, dropwise at first then, as it emulsifies, in a steady slow stream
when stiff and all oil added, whisk in 35ml white wine vinegar.
season with salt, pepper, pinch of cayenne to taste
Total time? 5 minutes?
Cyclopathic
Leicester.
Mods, shouldn't this be in technical know how?
Davidc
Somerset UK
Much as PK99 but I use sunflower oil.
Bit of a faff so only make it for special occasions and Waldorf salads. Must be made using eggs from free roaming free range hens.
slowmotion
slowmotion
Quite dreadful
lost somewhere
I picked up grapeseed oil, rapeseed oil and EV olive oil on the way home, together with some pricey eggs. I was going to return to my lab to experiment but a plumbing epic involving an iffy duct-mounted ball valve detained me.
summerdays
Cycling in the sun
Bristol
2) Making hummus
:smile:
Mayo - yuk so no point making it.
But hummous! When you can make lots of varieties! Currently it's a beetroot one in the fridge, and I'm contemplating a courgette version having found a recipe online and having a glut of the things!
And I tend to use Rape Seed Oil, since I now have a large vat of the stuff from the market!
srw
It's a bit more complicated than that...
2) Making hummus
The point about making your own hummus is that it's very easy (takes about 5 minutes in a blender) and the shop-bought ones are always too smooth and never have enough garlic.
slowmotion
slowmotion
Quite dreadful
lost somewhere
I have just emerged, boggle-eyed from the lab....
To start with:
2 yolks from pricey fresh Waitrose eggs (at room temperature)
Salt
Black pepper
Juice of half a lemon and a dash of white wine vinegar
A heaped teaspoon of Dijon mustard
Put all this stuff in deep bowl and blend it with a hand held blender (Argos do some electric stick blenders for about six quid)
The oil mixture:
100ml rapeseed oil
100ml grapeseed oil
50ml extra virgin olive oil
Put the oil in a small jug and add it to the eggs etc very, very slowly while you blend away. To begin with, add the oil drop by drop. Don't rush it. It helps if you move the blender up and down so that mixing is more uniform.. The mixture will start to thicken. When it does, you can add the oil more quickly. When you have added all the oil, you should have a lovely thick yellow mayonnaise.. I added half a dozen mashed capers and a crushed garlic clove at the very end.
IMHO, it's quite good. Alas, my food photography leaves a lot to be desired.
All that remains to be done is to invite @threebikesmcginty round to sample it.:hungry:
EDIT: The yellow colour comes from two ingredients
1) Waitrose's Clarence Court Burford Brown egg yolks
2) Farringdon's Mellow Yellow Cold Pressed Rapeseed Oil
