Cunobelin said:
There is a problem with all ofthese and that is a limited lifespan.
Due to very aggresive copyright protection there is no cross compatability between versions. So you cannot update a map you already own, or buy new maps without an expensive upgrade. Even subsidised to allow me to use the latest National Cycle Network and my present mapping the aditional cost for the Lake District alone is £60! The total upgrade is over £400 - not finacially viable.
For instance I have MM 2004 with a number of maps collected over the years.
Well yes, but I have a load of money invested in paper maps, if I want to get the more up to date version I have to buy all of the maps again - a much more expensive proposition than buying the digital maps again. Yes I'd be much happier if it were possible to get reduced price upgrades but the situation is no different than for paper maps: I know that the paper maps will stay, largely, unchanged and useable for quite a few years and the same is true of the digital mapping.
But it is deeply irritating that having bought maps I can only use them with Memory Map and if I wanted to convert to TrackLogs I'd have to buy the whole lot again.
Bikely and Mapmyride are good - but only if you're planning on sticking to the roads, and the mapping isn't as good as
Ordnance Survey.
Ordnance Survey seem to be experimenting with new approaches to making 'their' mapping available online, and their are some interesting experiments around eg
http://www.bikehike.co.uk/
which offers the best of both worlds. However at the moment it's a non-commercial service with a limit on the amount of mapping data it can serve. Hopefully it's the shape of the future.
Equally routes created on V5 will not load into 2004 for use on my present maps.
You simply need to export to GPX. OK it's a pain, but it's hardly a big drama.
In any event, while that may be a very legitimate criticism of Memory Map I don't know if the position is the same for Tracklogs.
