I'm a MM user too. If you can afford it, it is well worth buying the whole country at 1:50,000 (Landranger) scale. It's much cheaper overall than buying the 6 (?) regions one at a time. Also, you don't have the problem of routes crossing the borders between regions which are on on separate maps.Jonathan M said:Other option could be to buy your local area on Memory Map. You can plot routes and this will also give distance/height profiles etc. I've not used mapmyfitness but then having owned MM for a couple of years then I've not really had a need to.
