Hardtail MTB with the following specs , 15 inch or small frame in good condition apart from some scratches pictured in picture 3 which were done putting it in the back of an estate car. Otherwise the bike is in excellent condition, (the bobbles are still on the tyres) has had very little use probably less than 100 miles as I bought on a whim and prefer to use my Road bike.
Cash on collection preferred as this is an awkward item to send through the post. I travel extensively with my job so delivery or a meet up might be possible. £425. Collection from near Wellingborough Northants.
https://www.tritoncycles.co.uk/moun...rin-rocky-ridge-7-4-mountain-bike-2015-p14239
Frame
Series Three Alloy with SHOT Tech, 27.5
Front Fork
Rock Shox Sektor Silver TK Taper 27.5 Solo Air, 15mm Maxle Light, 130mm Travel
Crankset
Truvativ Firex 1.1 with GXP Hollow BB Spindle, 32-Tooth Single
Derailleur Rear
Shimano Deore Shadow Plus, 10 Speed
Shift Lever
Shimano DEORE, 2 Way Release, 10-Speed
Cassette
Shimano DEORE, 11-36, 10-Speed
Bottom Bracket
SRAM GXP
Chain
Shimano HG54
Hub Rear
Marin 4 Sealed Bearing, 142 x 12mm Through Axle
Hub Front
Marin 100 x 15mm Through Axle, 32 Hole
Rim
Alex MD23 with SSE, Tubeless Convertible, 27.5”, 32-Hole
Spokes Nipples
14 Gauge Black Stainless
Tyres
Schwalbe Nobby Nic, Performance, 27.5 x 2.25
Brakes Front
Shimano M445 Hydraulic Disc, 7” Rotor
Brakes Rear
Shimano M445 Hydraulic Disc, 6” Rotor
Brake Levers
Shimano Hydraulic
Handlebar
Double Butted 6061 Alloy, OS-31.8mm, 10mm Rise, 740mm Wide
Grips
Marin Micro-Knurl Double Locking
Stem
Marin OS Alloy Threadless, 31.8mm Bar Clamp
Frame
Front Fork
Crankset
Derailleur Rear
Shift Lever
Cassette
Bottom Bracket
SRAM GXP
Chain
Shimano HG54
Hub Rear
Hub Front
Rim
Spokes Nipples
Tyres
Brakes Front
Brakes Rear
Brake Levers
Shimano Hydraulic
Handlebar
Grips
Stem
