Had a bit play with it earlier, and like most of the nrich stuff, it's well put together. I suppose that there isn't a simple winning strategy (it appears that the computer's response has some element of a random response), although obviously, there is a symmetry to start off with which cuts down the possibilities a bit.
I was losing my initial attempts where the computer won with squares which had sides length (root(3), root(4), ... i.e. they went along a couple and then up/down one). However, a bit of concentration was needed to stop this.
One of the key patterns to stop / try and get is three isolated like
Then you're into a winning / losing end game as the opponent must counter with one to stop the obvious rotated square,
then you can put one in one of the other corners and there are two squares which could be formed, hence win / lose.
So a simple strategy is to form / stop a "<" type pattern being formed without any opposing counters around it.
