Merida eSpeeder Handlebars
Hi, very new to modern bikes so you will have excuse me. Ive just bought a used Merida eSpeeder 400. The handle bars on my old bike are 700mm wide and i thought I would change the ones on the Merida to the same width. But first I thought I would check that the length of the hydraulic brake tubes were long enough - which they are - I find that the hand grips have a grub screw to hold them to the bars and that they slide off the bars - my question is if I clamp the grips in a position that makes them 700mm - is this safe - there is still 100mm inside the grips - is this how they were designed and intended to be used
Sharky
Kent
Does that imply that the grips are installed with about 4 cm on either side, not supported by the handle bars tube inside?
Might give the desired width, but when braking, the grip might flex at the same time, so make the braking action less precise.
So I would say no.
Ajax Bay
East Devon
:welcome:
The (my) answer, since you ask, is 'no' and 'no'; and I think that having two limp dicks beyond the end of the metal is not a good idea. A few tens of miles on the bike and you'll mellow to the slightly narrower bars. Our bodies are wonderful things: they adapt. This 620mm bar is for urban: it's not as if you're wrenching it around black MTB trails.
https://www.merida-bikes.com/en/bike/4633/espeeder-200
