Hi,
I'm replacing cantilever brakes with mini v-brakes. Before I start cutting cables I thought I'd check I'm doing it right, if anyone can help?!
The brake cable for the front canti was in an outer all the way to this silver cable-stop. It was then bare down to the brake. With the mini v, I think it needs to be in an outer all the way to the noodle. So can I just add a short stretch of outer, with ferrules, from the silver cable-stop to the noodle?
For the rear, the cable currently goes along the top of the top tube, with cable stops at each end. There's then an extra cable stop above the rear brake allowing a short piece of outer to go round the seat post to another cable stop. This final stop is very close to where the noodle begins, but the angles are along wrong. So is it OK to just bypass this final stop an send a outer from the final stop on the top tube straight to the noodle?
Hope that all makes sense?!
Thanks.
Thanks.
