Modem Battery
Chris S
Birmingham
I've just bought a battery for my modem from ebay. It was manufactured in 2019 according to the sticker on it. Is it likely to hold a charge or should I return it?
markemark
How 'new' is it? Does it look used? What sort of battery is it?
Dogtrousers
Kilometre nibbler
I'm kinda surprised that you have a modem. It's many years since I had or saw such a thing. Does it make the squawk squawk boing boing noise when it connects?
I'm sure there's a perfectly good reason.
markemark
Most people have a modem but they generally now come combined with a router. It's still the modem within the box, that most refer to as a router, that connects to your ISP.
Your ISP (usually) supplies you with a router and modem combined. But call it a router. The OP may be calling it a modem (I don't know). Neither are totally right as it's usually combined.
If you buy a router independently, they usually don't have the modem built in. Non-home setups will often have a (or multiple) routers to connect devices . They'll then have separate modems for internet. Often more than one modem for load balancing and redundancy.
What I've not heard of before is a battery for a modem?
Dogtrousers
Kilometre nibbler
Your ISP (usually) supplies you with a router and modem combined. But call it a router. The OP may be calling it a modem (I don't know). Neither are totally right as it's usually combined. If you buy a router independently, they usually don't have the modem built in.
Bah. Newfangled rubbish. It's all been downhill since acoustic couplers disappeared.
Gwylan
All at sea⛵
Those days of scrummaging about under the desk in the hotel room to find the socket. Then find it was not in your collection of plugs.
Then setting things up to bounce through the hotel switch boards and so on.
Then faxing yourself at the hotel a document you needed to print.
Oh my, what fun we had.
Chris S
Chris S
Birmingham
Sorry, I have a Huawei mobile Wi-Fi that has an internal battery. The battery was sold as new. Is it still serviceable if it's been on a shelf for seven years?
markemark
What type of battery is it? for sure it would have degraded by different types at different rates. And it depends on the atmospheric conditions it is stored in which you have no knowledge of. If it were cheap I’d just carry on as life’s too short but if it was expensive then I’d ask for a new one.
sungod
depends on the exact battery type, if it's a lithium ion one, shelf life (i.e. disconnected, not charged) is generally 2-3 years, a deeply discharged l-ion cell may lose capacity and have increased risk of failure
if it's been sitting unused for 6 years, that's way too long, return it
