MontyVeda
- Lancaster... the little city.
since cyclists are thee best source of advice on all sorts of subjects....
i'm moving my oven 500m along the wall, I need to move a plug socket otherwise it'll be behind the oven.
Regs suggest 300mm minimum distance from a hob, which means the cable to the socket isn't long enough, so I'm planning on extending it...
waterproof electric box, screwed to wall with a 30amp terminal block to connect the wires... the box will end up behind a kitchen unit just above the skirting board with the cable extension running vertically up the wall to the socket's new position. All the cable will be housed in trunking and there will be no chance of it being pulled from either end. I'm no electrician and to me this looks OK... am i creating an accident waiting to happen???
