BigonaBianchi
Yes I can, Yes I am, Yes I did...Repeat.
- Iskele TRNC & Mordor UK
..ok so I have had a series of punctures, and they are all from the inside of the wheel. They are NOT pinch punctures from the tube getting stuck under the rim or anything...I had the rim tape changed because there was the smallest of kinks in the tape at the point of puncture..that seemed to work ok for a while until tonights ride when it punctured again..in the same place. Looking at the rim tape it seemed ok but had moved a small amount across the rim instead of being centred along the inside of the rim.
So I changed tube and it punctured again...I wont go into the debacle of the broken halfords track pump and the totally unfit for purpose halfords mini morph
So...short of switching to solid rubber tyres I need to have much stronger inner tubes I reckon. The tubes I have seem to be thinner than a featherlite condom
Can somebody please suggest a brand of tube for a 23" 700 wheel that is made of heavy duty durable rubber instead of gossamer extra sensitive??
Ta in advance..
Totally peed orf of old worving town
)....So...short of switching to solid rubber tyres I need to have much stronger inner tubes I reckon. The tubes I have seem to be thinner than a featherlite condom
...Can somebody please suggest a brand of tube for a 23" 700 wheel that is made of heavy duty durable rubber instead of gossamer extra sensitive??
Ta in advance..
