figbat
Former slippery scientist
- South Oxfordshire, UK
- DPF clogs up.
- Bit of redex and clears up.
By what mechanism does Redex clear a DPF?
DPFs block up in two ways:
(1) filling up with soot from the incomplete combustion of fuel. This is what they are designed to trap. Soot is carboniferous and so can be cleared from a DPF through heat - get the DPF hot and it burns away the soot. DPFs can be heated up passively or actively according to how the engine is running. The ECU monitors the pressure drop across the DPF and when needed will trigger an active regen session. Passive regen happens when using the engine hard, increasing exhaust temperatures.
(2) filling up with ash - a residue of the combustion of engine oil. Engine oil contains metallic elements which, when burnt, become metallic oxides (ash). You can’t clear ash by heating the DPF up because ash doesn’t burn. You can only clear it through mechanical or chemical cleaning. The chemicals needed to dissolve the ash are fairly potent and won’t survive coming through the engine combustion process, certainly not at the levels added to a tank of fuel.
