AlanW
- Not to sure?
So lve just picked up the Kenisis Ti bike, fully built up by the LBS.
Really pleased with it apart from how the front SKS mudguard mounts on the rotor side.
Looking at the photos, you can see that they have had to place a couple of washers under the Secu-clip in order to space it away from the fork leg. But in doing so, as you can see, it is now hard up against the hydraulic hose. So dammed if you do dammed if you don't.
Even with the two washers, the Secu-clip is still hard up against the inside of the fork leg. So over time, l suspect it will rub and fret against the carbon weave.
Any ideas how l can improve this or am l just being fussy?
As a point of interest, but Kinesis own brand "Fend Off" mudguards simply bolt straight on with no Secu-clip at all?
So the quick fix to make it look neater is to remove the Secu-clips and simply bolt the stays direct to the inside of the fork legs.
Unless someone can give me a better solution in the meantime?
