GrumpyGregry
Here for rides.
Which order?
The brakes have two serrated washers. The lamp bracket comes with two much thinner serrated washers. Assume I swap the originals with these.
Instinct says is it brake, two (thin) washers, lamp bracket, mudguard bracket but what says the hive mind? Is that right?
(reality is a washer will also have to go somewhere behind the lamp bracket and the front face of the fork to stop it fouling the headset - yes, I probably now need a longer brake nut)
Images of how you put this all together on your bike gratefully accepted.
