My Doctor wont prescribe Omeprazole any more.
gbb
Peterborough
Esomeprazole is the single active isomer of omeprazole, which is a racemic compound (mixture of left and right handed isomers). It's effectively double strength for the same dose vs omeprazole.
Nexium is a trade name (actually the original trade name) for Esomeprazole - they're the same drug.
Well you live and learn. It may be the 'system' , having noted the concerns about omeprazole have shifted people to what sounds like something else ? (I am a cynic admittedly, it might be as simple as availability or cost that drive that change in our case)
albion
Gateshead
Update.
1st, thanks for all the advice.
Spoke to the Doc again.
She has been concerned about my low magnesium count for some months. I have regular blood tests to monitor this problem.
Apparently Omeprazole** is linked to this problem.
Its this, plus being linked to the to dementia that has decided her.
**Google tells me that it is linked to low magnesium and that can be serious.
I will have to get my head around this. I dont want to be stuck on 2 tablets every day for life.
" In approximately one-quarter of the cases reviewed, magnesium supplementation alone did not improve low serum magnesium levels and the PPI had to be discontinued."
I assume supplementation was tried, it looks like it works in 75% of cases
roubaixtuesday
self serving virtue signaller
No idea about your specifics, but for sure you can't be "changed" from esomeprazole to Nexium for medical reasons - Nexium is esomeprazole.
  • Like
Reactions: gbb
Dave7
Dave7
Cheshire
I have been taking Magnesium with vitamin B6 tablets. My latest blood test showed that I am right at the bottom of what is acceptable.
albion
Gateshead
Whilst I take magnesium with zinc I also have some glycinate ones, magnesium glycinate supposedly the one that is most absorbable.
All the others do not absorb well apparently.
albion
Gateshead
My cheaper Zinc + Magnesium (+B6) specify ..Oxide and then ..Citrate as ingredients. Citrate thus works well but is unquantified in the 300mg magnesium specified. Lesser obviously.
kingrollo
Key word here - guidelines - does that mean under no circumstances they should be prescribed ?- A good GP will weigh up the benefits v risks and provided the risks are explained and understood by the patient - then can go ahead.
As you get older you have to balance the trade offs - I am in a similar position with NSAIDs after a heart attack - Despite the risk I do have to very occasionally take them
Drago
The Urban Fringe
Nice guidelines are odd.
Theyre not mandatory as such. However, they are considered best practice and it is expected that all practioners will adhere to them so in practice they are effectively mandatory (albeit not stated as such), and can only be sidestepped in the practioners professional judgement or in the interests of patient care.
kingrollo
But I would have thought in the interests of patient care provides a lot of flexibility
wafter
Oxford
To chuck a spanner in the works there's apparently conjecture over whether some cases of reflux are actually due to excess stomach acid, and that PPIs such as Omprazole that suppress acid production can make it worse / foster dependencies in the long term.
Might just be internet quackery but potentially worth a look...?
