Need advice with bike purchase
Nomadski
I Like Bikes
LBS, Usually
Ive found what looks like a good bike at a decent price, its a Cannondale Caad 8 Tiaagra - £679.99 (brand new, but 2011 model)
Here are specs
(2011)
Options
51cm - In Stock (Already calculated this is my right frame size)
Frame
CAAD8 SI Alloy
Forks
Cannondale Ultra Carbon
Rear Derailleur
Shimano Tiagra Long Cage
Front Derailleur
Shimano Tiagra
Shifters
Shimano Tiagra
Chainset
FSA Omega MegaExo, 34/50
Bottom Bracket
FSA MegaExo
Chain
KMC 9 speed
Freewheel
SRAM PG-950 12-26T
Headset
CAAD8 SI
Stem
Cannondale C4, 31.8mm
Handlebars
Cannondale C4 Compact
Front Brake
Cannondale C4 w/cartridge pads and cold forged retainer
Rear Brake
Brake Levers
Shimano Tiagra
Rims
Maddux DRX 4000
Front Hub
Formula RB-51
Rear Hub
Formula RB-52
Spokes
Stainless Steel
Tyres
Schwalbe Lugano 700x23c
Saddle
Cannondale Stage w/ Steel Rails
Seatpost
Cannondale C4
You guys know way more stuff than me (ie I know NOTHING) so does this seem a good deal? What would you change out / put in? Can do a certain amount of customisation if I know what I want putting in. I know I may want a gel seat..
Seems the chain sucks according to a few reviews Ive read, any suggestions?
I plan on doing long runs, so wanted a Sportive racer, but I find it hard to distinguish between "normal" and "Sportive" road racers - some sites don't tell you.
Nomadski
Nomadski
I Like Bikes
LBS, Usually
Delete pls.
Rob3rt
Man or Moose!
Manchester
Sounds like a good price IMO. The Cannondale CAAD frames are regarded as one of the best if not the best alu frame around, they are comparable to many manufacturers carbon offerings in terms of weight and lateral stiffness.
You should check whether this edition of the frame has a bb30 bottom bracket shell, and if it does, find out if it comes with a bb30 chainset. It may have had an adapter fitted to run a standard chainset.
Forget the gel seat..... you might need a new saddle, but you wont want a soft gel seat, hard and well fitting > soft.
As for sportive bike, essentially the main difference is a taller headtube, hence providing a more upright position, in the Cannondale range the Synapse is the "sportive" bike. The CAAD is an out and out racer.
Nomadski
Nomadski
I Like Bikes
LBS, Usually
Are the chains and chainset two different things? (Really a beginner here!). What is the significance of the bottom bracket shell? Im guessing the adapter would be bad? May have to look at Synapse bikes then if they are better for longer runs.
Rob3rt
Man or Moose!
Manchester
In the most basic terms, chainset is the part where the pedals attach that has the front chainrings (the front gears as we called them as kids).
The chain is, well the chain.
The bottom bracket shell is the part that holds the bottom bracket (i.e. the bearing and axle arrangement to which the chainset attaches). BB30 is just a standard, but it is theoretically better than other standards, so the adapter in some ways is a bad thing, its an extra interface for one and it negates some of the benefits of the BB30 design. On the other hand it doesn't matter all that much, but I would say if its not BB30 or if it is running a converter, then you should be looking for the full Shimano groupset if you are going to have the bike customised at the point fo sale, in this case it has a 3rd party chainset instead of a Shimano one. If it is BB30 and is not running an adapter, the 3rd parts chainset is expected because Shimano dont make a BB30 compatible one. I mentioned BB30 because it is a standard created by Cannondale so features on their bikes a lot and the bike you posted is made by Cannondale.
The Cannondale Synapse might suit you better, have a test ride of both if possible and then decide. The Synapse is more relaxed and comfortable, which suits many people, the CAAD frame is more aggressive and stiff, built for racing. Although it is still perfectly good for long rides.
Nomadski
Nomadski
I Like Bikes
LBS, Usually
Thanks for the info Robert. With my prior history of lower back issues Im thinking the less aggressive but still speedy and more comfortable Synapse is the way to go.
Looking at either
CANNONDALE SYNAPSE ALLOY 6 TIAGRA (2012) £759.99
http://www.paulscycles.co.uk/products.php?plid=m7b0s6p4331
or
CANNONDALE SYNAPSE ALLOY 5 105 (2012) £879.99
http://www.paulscycles.co.uk/products.php?plid=m7b0s6p4332
Specs of each -
Frame - Synapse Alloy, Optimized 6061 Alloy, SAVE, BB30
Forks - Synapse SAVE, carbon blades, 1-1/8"
Rear Derailleur - Shimano Tiagra 4600
Front Derailleur - Shimano Tiagra 4600, 34.9mm clamp
Shifters - Shimano Tiagra 4600 20 Speed
Chainset - FSA Omega, BB30, 50/34
Bottom Bracket - FSA BB30
Chain - KMC X10, 10-speed
Freewheel - Shimano Tiagra 4600, 12-28, 10-speed
Headset - Synapse Si, 25mm top cap
Stem - Cannondale C4, 31.8, 6 deg.
Handlebars - Cannondale C4 Compact
Front Brake - Cannondale C4, dual pivot, cartridge pad, long reach
Rear Brake - Cannondale C4, dual pivot, cartridge pad, long reach
Brake Levers - Shimano Tiagra 4600
Rims - Maddux RS 3.0, 32 hole
Front Hub - FORMULA RB-51
Rear Hub - FORMULA RB-52
Spokes - Stainless Steel, 15g
Tyres - Schwalbe Lugano, 700x25c
Saddle - Cannondale Stage Ergo w/ Steel Rails
Seatpost - Cannondale C4, alloy, 27.2 x 300 mm
Grips - Cannondale 3 mm Suede w/ gel backing grip tape
Or
Rear Derailleur - Shimano 105 5700
Front Derailleur - Shimano 105 5700, 34.9mm clamp
Shifters - Shimano 105 5700 20 Speed
Chainset - FSA Gossamer, BB30, 50/34
Stem - Cannondale C3, 31.8, 6 deg.
Handlebars - Cannondale C3 Compact
Front Brake - Tektro R539, dual pivot, cartridge pad, long reach
Rear Brake - Tektro R539, dual pivot, cartridge pad, long reach
Brake Levers - Shimano 105 5700
Rims - Shimano RS10
Front Hub - Shimano RS10
Rear Hub - Shimano RS10
Spokes - Shimano RS10
Tyres - Schwalbe Lugano 23c
Saddle - Cannondale Stage Ergo w/ Crmo Rails
Seatpost - Cannondale C3, carbon wrapped, 27.2 x 300 mm
Is the 105 worth the extra £120 layout over the Tiagra?
Are they decent prices? (£759.99 and 879.99).
Thinking back to what you've been talking about, the frame I presume is still a Cannondale one given the Synapse name?
Cannondale C4 v Tektro R539 brakes? Been hearing mixed stuff about Tektro?
Again, any elements in these lists worth replacing with alternatives?
Anything else worth checking with these two bikes when I visit the LBS?
I notice both have the BB30 bottom bracket.
I will still have a ride of the Caad, but everything you have said matches up with general consensus and certainly seems to be a better prospect for me, I'm never going to be winning any races anyway, Im doing it for personal challenge, fitness and fun....even if I come in last. But I still want to be relatively comfortable with the best budget gear I can get for the price.
And thanks again for your info Robert, learning a great deal already.
