need Tights / Bibs for Winter...
Not sure if Decathlon are still doing them, but that have bibs with A-Tex windproofing in them - I use these when it gets down to zero. There is a pad, but it's thin and not shorts quality, so still use my shorts under.
Hacienda71
Cheers - you in a large?
[edit]would you say they are good enough for a few degrees south of zero?
Mine are a large but they are pretty stretchy. The roubaix material seems good down to about freezing I wear bib shorts with them as well, but they don't have windstop panels so on a really cold day I would tend to wear ( yes @potsy I know) Aldi ones or the Biemme ones I had on on Saturday both of which have windstop panels around the knees and are just that bit better in really cold weather.
potsy
Rambler
My Armchair
I wear my Altura Winter cruiser tights when it's cold, very warm with a fleecy feel to them.
Only trouble is they are waistband and not bib tights, quite fancy a pair of bibs next time.
400bhp
Think I will look for ones with windstop then.
400bhp
Buy and keep both, then use the shorts with leg warmers on days when the weather isn't a dead certain?
I've too much cycle clothing & I know they would be wasted.
3 pairs of running tights. Decathlon £20 jobbies fine down to about 5 deg. Got bib shorts for weekend. No need for 2 pairs of shorts for weekend / occasional use.
Got loads of stuff for the commute.
I'm really after some longs that will be good for 5 deg down to -5.
Rob3rt
Man or Moose!
Manchester
Can't help with the cold weather clothing at the <£60 budget, I paid a handsome sum for my winter 3/4 and tights (rated 0-15 degrees), well worth it IMO and they are very warm but it is mostly an extravagance (I bought them when something good happened financially speaking - not a lottery win :tongue:) and there are likely cheaper tights out there that will perform at least nearly as well if not as well, I just don't know of them.
NorthernSky
NorthernSky
^ ah yeah that too :whistle: :tongue:
not sure how it will work out for me cause i ordered two pairs for fitting. think the £5 off has went against the pair i sent back, oh well
