betty swollocks
large member
Giving these a whirl this morning
You what? It looks like the classic comfortable North Road positions, but with an extra front tri-or-accessories loop. I'd worry about the weld, but I've cracked bars in a crash.They look like a lot of excess metal and would appear to put the hands/wrists in an awkward and uncomfortable position.
Are your hands on at right angles to normal or something? And I don't think they're quite swept enough to get the way of the knees for 99.9% of turns (you'd need to be almost stopped to turn more, hence not pedalling, hence no knee-banging) and even if they were, you get used to putting your knee outside the bars for one or two pedal revs, like I do with Porter bars.I can only see those bars causing wrist pain due to the unnatural position, they are also likely to interfere with your knees when turning.
headset bearings seized? No need to clean or replace them, just use MORE leverage
Have you tilted the levers far enough that you can only just see them over the top of the bars from your usual sitting position? I can't tell from the angle of the photo. I find that much more comfortable, but so many people have their flat bar levers almost horizontal in front.Main hand position i.e. holding the grips, feels entirely natural: the Rohloff twist grip is very easy to operate and the brake levers are within easy and instinctive reach.
Brake levers are sticking out straight in front pretty much, but tilted down a bit.Have you tilted the levers far enough that you can only just see them over the top of the bars from your usual sitting position? I can't tell from the angle of the photo. I find that much more comfortable, but so many people have their flat bar levers almost horizontal in front.![]()
Thank you. I do.They certainly look "interesting" but if you find them comfortable and they do the job, then go for it and who cares what others thing. Judging by the jersey in your avatar you know what you're doing on a bike![]()
That jersey was for three times up Ventoux in one day.
It was a memorable day.
