Hello,
I have a 2009 Trek 7.3fx Hybrid. Recently I changed the BB, Front Mech, chainset and cassette because they were all a bit knackered after a few years of hard riding.
Everything was fine until I put the front mech on. Even if I pull it as far as possible from the bike, the outer edge only ever comes parallel with the chain, and not slightly beyond it. Therefore I can't change into the top chainring.
I've tried changing the end stop screw, but this doesn't make enough difference. Now I made sure that the new Shimano BB was exactly the same length as the old one (quite long at 122mm). Is it possible or likely that the new chainset might be a bit thicker than the old one, and so I need to get a shorter BB, rather than replicating the old one?
The old front mech was a Shimano C102, new one is a Shimano Alivio FDM412, new chain set is Shimano FC-M411 Alivio 48/38/28T, instead of original M361.
If anyone can help or advise I would be extremely grateful!!
). But I expect either chainline would work fine but worth checking (it is the centre of the seat tube to centre of middle ring) that it is not something outside the two for whatever reason.
