New rear wheel for loaded touring - advice
scragend
Asking for a friend - genuinely!
My friend and I have just come back from a week's touring in the Netherlands. He has a Trek Domane bike, one of these:
https://www.trekbikes.com/gb/en_GB/...omane-al-2-gen-4/41587/?colorCode=red_reddark
He had a problem over the week with spokes breaking - it happened twice. We went to bike shops and had them fixed both times. He's a big fella - 6 foot 8 and a little bit heavier than he probably should be (by his own admission and he doesn't mind me saying this here).
We did a similar tour last year and there were no problems then but obviously it's not ideal to have spokes keep pinging like that.
I had a look at the wheels on his bike and they're only 24 spoke and I don't think they're heavy duty enough for this kind of riding. He tours with loaded panniers.
The wheel spec according to Trek is this:
Hub rear
Formula RX-142 alloy, 6-bolt, Shimano 11-speed freehub, 142x12 mm thru axle
Skewer rear
Bontrager Switch chamfered thru axle, removable lever
Rim
Bontrager Paradigm SL, Tubeless Ready, 24-hole, 21 mm width, Presta valve
Spokes
14 g stainless steel, black
Tyre
Bontrager R1 Hard-Case Lite, wire bead, 60 tpi, 700x32 mm
Am I on the right track in thinking that a beefier rear wheel (36 spoke?) would help? And if so can anyone point me towards a suitable one? He isn't into bike mechanics so has asked me to look into it for him.
Ming the Merciless
There is no mercy
Inside my skull
Yes more spokes the better for resilience / reliability for touring. The other thing he could look at is wider tyres at lower pressure to cushion the ride more. Plus is he the sort of rider who just ploughs through pot holes etc?
roubaixtuesday
self serving virtue signaller
Would suggest to contact a touring specialist (sjs, spa etc) and get them to build one.
I'm *not* an expert here, far from it, but the rim choice, type of spoke and quality of build all matter as well as spoke count.
Dogtrousers
Lefty tighty. Get it righty.
Another complete non-expert on wheels here.
My observation is that, although I'm on the heavy side(90kg+) I've never suffered from broken spokes, except for one wheel that had multiple failures. It wasn't a low spoke count wheel. It was just a crap wheel
Maybe your friend has a similar misfortune?
S
scragend
Thanks everyone, I'll pass all that on.
I don't think he's put the wheel through much abuse. Perhaps it's just misfortune but I think a wheel with a higher spoke count and as good a quality as he's prepared to pay for will be the way to go.
Thanks again
Sharky
Kent
Probably overkill, but you could investigate tandem rear wheels.
