Delathon is the best choice, infact it's perfect for your budget then the TDF. I'd steer clear of Viking.
Is there much difference between the decthlon and carrera? Out of the two i personally prefer the carrera but i would rather quality if there is a big difference
I may look second hand if i cant find a reasonable new one. It mainly just for commuting than anything else
They both have Shimanos bottom end groupos (2300) The TDF has a Hi-Tensile steel fork, it'll soak up rough road vibrations, but not very good (I have a chro mo steel fork on my Defy not very good) The Decathlon has a carbon fork which will be smoother on the roads as carbon flexes. Also the Carrera weighs 12kilos and the Declathon; 10.5kilos which you will notice.
Make your choice though as it's your money.![]()
Ok thanks for the advice. Think i might head down and get one tomorrow. One final question, do road bikes have a weight limit?
Edit: was looking at something from triban and it says "This bicycle, and particularly its braking system, is designed for a maximum load of 100kg (220lbs). For example, for a bicycle
weighing 13kg (29lbs) and carrying 5kg (11lbs) of luggage, maximum user weight is 100-13-5 = 82kg (181lbs)."
Does this sound about right as i weight more roughly 90-95kg
Im not exactly fat. Its just im about 6ft3 and naturally quite big built. Would i be fine with this bike or not?
Ill definitely go with the bike you suggested if possible though.
Apologies wasn't taking offence. Yeah you'll be fone get your ride position has comfortable. And off you go
