Rhythm Thief
- Ross on Wye
snapper_37 said:Keep it up! I'll think of you when having a nice blend in a liquorice wrap later![]()
You're not helping ...
ChrisKH said:Having said that I'm a non-smoker, so even a wisp of permeating smoke and I would be up in arms. Are you a smoker Andy?
Rhythm Thief said:You're not helping ...![]()
Andy in Sig said:I'm a non-smoker and I detest it in that being near smokers ruins an evening out for me. That said, while I approve of recent legislation protecting non-smokers I think we've been too hard on those bent on suicide by tobacco e.g. I think firms should provide smoking rooms for them rather than chucking them out on the street for a fag.
RabbitFood said:Next door neighbor smoking and is stinking the bedroom out - is there anything I can say to her?
RabbitFood said:We live in a 1960s ex council house and mid terrace, the only brick walls in the house are on each side, the women next door smokes like a chimly and in the past 2 weeks the smell in our bedroom is of smoke and rather disgusting.
is there a law preventing her from doing this or do I just have to go and upset her, I don't really get on with many other neighbors so one more will not bother me too much!
any advice appreciated.
Rabbit
Rhythm Thief said:I I spent 35 years as a non smoker and it never bothered me that much when other people smoked near me. Not even enough to try and stop people lighting up at the same table in a pub, and certainly not enough to stop someone lighting up in the house next door.
peanut said:thats ok then is it ? because something doesn't bother you , you don't see why it should bother anyone else.
What a selfish attitude . Unfortunately typical of most smokers I find![]()
peanut said:you have my complete sympathy wabbit.
I have the same problem with one of my neighbours.
I would suggest you contact your Housing Officer in the first instance . Ask for a visit and show her the problem. Don't mention it to your neighbour and I suggest you request your HO doesn't either. It will create bad feeling and solve nothing She is not going to stop smoking!
Once your HO is aware of the problem she should either contact the repairs or maintenance dept or support your call . Although not strictly speaking a repair there are various things reppairs can do to help with the situation.
You need to check under the floors and in the loft near the deviding wall to make sure there are no holes or gaps in the deviding wall brickwork or blockwork.
Next you need to look at your windows. Check the frame to ensure the sealant is still intact all round. Then check the rubber seals on all the opening sashes (I assume that you have Upvc ?)
Its highly likely that the smell is coming through your window around the opening sashes where there are always slight gaps.
Easy to test simply cover your window in plastic sheet and tape to the frame if the smell stops you have found the ingress point
Hope that is helpful
Rhythm Thief said:You're reading rather a lot into my post there, I'm struggling to see where I said that. Why not quote the post I made after this one as well? Or why not acknowledge that someone smoking in their own house is not usually a cause for other people's concern?
peanut said:Your post seemed to inply that because the smell of smoke was not an issue to you it shouldn't be to anyone else ? was I wrong in my interpretation ?
thats a rather a selfish attitude typical of most smokers I find![]()
