pawl
- Desford Leicestershire
Shortest day(Winter Soltice) is the 21 of December.
Correct, but the latest sunrise and earliest sunset are not on the same day, and neither of them are on the 21st.Shortest day(Winter Soltice) is the 21 of December.
Still getting smaller til the 21st.
Probably something to do with the shape of earth and shape of orbit, neither of which are perfect circles.I understand the principle that "true" midday isn't at 1200. But why does the rate of change in the sunrise time differ from the rate of change in the sunset time?
Look up what an analemma is, this is a visual explanation of other factors (like time of day, shape of orbits, earth having a tilt, latitude etc). It's not that an equation of time explanation is wrong, it's that you can visualise what the heck we're on about here.
http://www.sciquill.com/analemma/page2.html
N.B. to be clear, the explanation of the perihelion (earth being closest to the sun in January) is not lined up with the solstice is essentially the same thing.
Also Analemmas are not vertical when you move away from midday (excluding tilt). They become asymetrical figure of eights that are rotated from vertical. The latitude also matters.
You've put that much thought into it, you lost the 11 seconds from today.OK, that makes sense now. I had previously assumed (without putting any thought into it) that any analemma would be a vertical line
