No. I aint riding a fixed...
downfader
extimus uero philosophus
'ampsheeeer
..so why are my cranks turning when I push the bike walking on the pavement? Not happy, fear something has died or is dying in the rear hub. :angry:
Rohloff_Brompton_Rider
Formerly just_fixed
sounds like the hub is dirty inside or a pawl spring is busted / weak. easy to strip and check. a good clean and lube might sort.
it could also be a bearing going / gone, again only a strip n tell will do.
downfader
downfader
'ampsheeeer
[QUOTE 1162947"]
Nothing has died in the rear hub. It's just the force required to push the internal hub body through the ratchet is not there becuase you are walking with the bike and there is no force on the pedals. Try running and see if it happens.
[/quote]
Already ran with it this morning up a small hill. Still does it.
[url="http://www.cyclechat.net/user/4887-bromptonfb/ said:
bromptonfb[/url]"]sounds like the hub is dirty inside or a pawl spring is busted / weak. easy to strip and check. a good clean and lube might sort.
I've done 4000 miles since the wheels were bought last summer. The other day I hit what I would describe as a trench as I entered the car park into work (and did me back in with it). Will see how I go with it, if it gets worse I'll take it into the LBS.
Its been slightly annoying as my pedal has clips and the leather has been rubbing off on the deck. It used to look nice. :wacko:
Formerly just_fixed
4000 miles without a service to me sounds a lot, especially, as i assume with those miles, you've ridden it thru winter. it is not a difficult job, easy to learn and will save you money in the long run.
downfader
downfader
'ampsheeeer
Mostly in dry weather tbh. I tend not to extend the commute during winter either.
