The left one I bought from a tool stall in Leeds Market in the late 2000s, cost about £6. I never had a reason to doubt its accuracy. I mislaid it around the new year so bought another at Toolstation. This was a Minotaur branded tool for £14 in a nice plastic case and it certainly feels well made so I was happy enough.
I was measuring the seatpost of a new bike so I could design and 3D print a clamp to hold the mudguard. The measurements didn't seem quite right. Thought maybe the post tube wasn't properly round, or I was measuring in different places. Then my old one turned up and didn't agree with the new one. Now I know why.
On the left caliper the bit measures 5.51. I think there's a smidge of parallax in the photo as it looks about 5.50 but to the careful eye it comes up between the 5.50 and 5.52 marks. Either way you can see it's around 5.5mm as the bit is labelled. The right one measures about 5.35. Way under.
Yes both are inexpensive tools, but they're still supposed to have a reasonable degree of precision, or you might as well use a plastic ruler.
Don’t fret. The French did their sums for the length of the Metre and got them wrong. Took them years to fess up. Some would say accurate to a tenth of a millimetre -was- a reasonable degree of precision.
If you are using an inaccurate measuring device it only matters if you give the measurement to someone else. If you pay £14 for a caliper it is likely to be as accurate as a tape. Many years ago we used to have slip gauges (iirc) for checking accuracy of tools for machining.
All I’ll ever use at work / for anything remotely serious at home. For all the reasons you’ve stated and more….. 👍
EBAY LINK: https://ebay.us/m/R6bLjz
does it read 0 at 0 ?
if not, it's probably had it as there's no sign of any scale adjustment
if it does read 0, check if there's a lot of play between the slider and scale - with play, the jaws might become skewed wrt each other, which'd cause reading error, there may be some screws to adjust the amount of play, often at the top of the slider either side of the locking screw
Yes, the only thing that puts me off though is the number of fakes about. How do you know you're getting the genuine article?
