Maz
How do I clean a heatsink?
My PC fan goes into noisy overdrive if I have more that one internet window open.
I took off the side panel and gave the fans a clean. Then I removed the processor cooling fan and couldnt believe how much dirt there was between the fins of the heatsink (see photo).
Is it OK to remove this dirt with a vacuum cleaner?
Can the heatsink be removed to clean it better? If so, is the heatsink normally attached to the processor with conductive grease?
Any help appreciated. Thanks
IMO I'd always take it off to do it, then you don't need to worry about static zapping the CPU (but make sure you earth yourself for any work inside the case). So you'll need paste to remount it. Get some 'arctic silver' compound. It's awesome.
