Non-OEM chainring - anything I need to know?
Kell
My chain snapped this morning (I'm OK - just had a three mile walk home in SPD shoes).
I was toying with the idea of getting a slightly smaller chainring this time around and am looking at a non-OEM 48T one.
I'll buy a new chain, new sprockets and this new chainring together and replace the lot. Any problems with a Brompton chain on any other chainring or will they all play nicely together?
Kell
Kell
(Was going to delete this thread, but I can't)
Just looking back at a previous thread (also by me) it appear the only thing I might have to do is remove a couple of links. Going to order this with a corresponding chainring:
https://www.spacycles.co.uk/m8b0s210p3387/SPA-CYCLES-130-BCD-Zicral-Outer
Kell
Kell
I hope you aren’t buying a new chain ring because your chain broke. The two things will not be related.
Nope - When I replace my chain, I always replace the Chainring and sprockets.
Do it twice a year regardless of whether they need it or not.
Long story short but after trying to make a chain last longer than it should, it snapped, depositing me on the cross bar of my then Dahon folder.
I broke my Cocyx, was off the bike for at least three months, and still have problems today if I have to sit down for extended periods - like any car journey over two hours.
So, as I need to replace my chain, and would be buying a new chainring anyway, I'm going to try a new one.
All things considered it's cheaper to spend £100 a year on the drivetrain bits than to be forced into driving to the station for three months and getting the tube the other end of my journey - just being off the bike for those 3 months cost around £16 extra a day. Over three months, that's almost £1,000 - which was enough to buy a new bike at the time.
Kell
Kell
mitchibob
Treorchy, Wales
Cripes - I honestly can't see any point in doing that.
Not sure the chainring needs it each time chain is changed, but sprockets do, and I can quite easily seeing having to do it twice a year.
Kell
Kell
My chains only last six months. The grime that comes up from daily use in London turns into a horrible grinding paste that really plays havoc with chain, sprockets etc.
This is what I used to get out of my chain pusher every month. Terrible design that allows the grime to build up in there.
View: https://www.youtube.com/watch?v=E4nh0aEiBeI
I'm no longer commuting five days a week, so I may get longer between changes as I’m doing fewer miles as we’re only in the office three days.
Checked this one about a week ago when I cleaned it. the 0.5 side would go in, but only just. So it wasn't too stretched, but there you go.
In 30 years of commuting, I’ve never got away with changing a chain and reusing the old sprockets, though I used to get away with not changing the chain ring.
But in this instance, as I was interested in trying a slightly smaller chainring, I thought I'd swap everything.
rogerzilla
The derailleur bikes benefit from the chainguard as a chain catcher. My 2-speed will unship the chain to the outside if changing to a smaller sprocket in a hurry. I avoid it by pedalling slower while changing.
